Hi Dmitry,
I setup a squid proxy server to isolate Windows machine running RB and prevent Windows Services to connect to Internet (no default gateway setup). The proxy has no login/password.
Unfortunatly I cannot use RB broadcasting with proxy setup. I tried those setting but none worked:
192.168.1.128:3128
http://192.168.1.128:3128
proxy:3128
The proxy works for Firefox and Dropbox for instance!
Could you please confirm it should work?
Also does the proxy works for HTTP GET request under Reports settings ?
To be more precise I am using the HTTP GET feature to update the last played tracks on my website and I use a private IP (ie 192.168.1.70) but I can use the public IP of the website easily. I also use the HTTP GET to update onto TuneIn so I need the proxy to go to Internet. As a workarround I can do the TuneInupdate from my website server I just need to know
Thanks. Christian
192.168.1.128:3128
proxy:3128
Thanks. Christian
