Question priority
ibek95
Hi Dmitry, I have a question about priorities: If I have tracks with over 100 does this work then? For example I set all tracks with the tag "new" increase by 90 in the playlist generator and some of those tracks also have set via track tool "9" (+30). Does this work then? It then must be a value over 100, right? Or at least it is 100 maximum with those settings?
The priority value is capped at 100 so it can't go beyond that.
Ok, so in this case (theoretical a number over 100) it will be 100 no matter what? Or must I set it in a way that it is exactly 100?
The value is capped to be in range [0..100]. Anything below 0 becomes zero, anything above 100, becomes 100. Priority 100 means: about 4x times the chance of being selected compared to default priority (which is 50).
