Radio Mixer
colm said:
hi there,
can anyone recommend a good Radio Mixer to broadcast shows with radio boss
thanks
How many channels will you use? Will you have phone calls? How do you intend to use the mixer?
hi,
i intend on using 6 channels, and will have a phone call in operation later on.
i want to use the mixer for broadcasting live and pre recorded shows on my internet radio station.
www.radiovera.ie
thanks
colm said:
hi,
www.radiovera.ie
thanks
May I know what for are used all the channels? How many MIC's, how many phone callers, what audio etc., etc ? The radio station is only for internet broadcasting or mixed? There are a lot things to know. Becouse it is important to know how many AUX's the mixer to have. For example a mixer with USB is very good in some conditions. But I'll wait for your answer.
hi,
2 channels for microphones,
2 channels for cd player input
1 channel for phone
the phone channel will be added later.
the radio station is used for internet broadcasting.
i originally bought the numark m101 usb 2 channel mixer , and this did not work for broadcasting.
is radioboss user friendly with an external mixer.
Yes, RadioBOSS is very user friendly with an external mixer.
Check this video training.
http://www.youtube.com/watch?v=91htw_uzYTc
You need two soundcard in PC. If you have a mixer with USB (I recommend) you will have another soundcard directly from the mixer.
We use Allen&Heath XB14 with USB.
Hello again,
i currently have just 1 Soundcard in my pc, if i bought an external soundcard like the picture i have attached.
Would this work as a second soundcard.
my current Numark M101 USB Mixer has a Two-channel rackmountable mixer with USB.
I tried for weeks but could not sync it with radioboss.
thanks
colm
colm said:
Hello again,
thanks
colm
That USB soundcard is very good. I use one exactly like yours (Logiteck 7.1). I do not recommend Numark as mixer for RadioBOSS. It is used most by DJ's (http://www.youtube.com/watch?v=1Up54xiemkU). It is very, very limited.
thanks,
i will invest in the usb soundcard, would you happen to know what mixer is used in the RADIOboss tutorials.
And is there a link for all the radioboss tutorials.
hello once again,
thanks for all your assistance so far.
Can i get your expert opinion on this mixer. its comes with good reviews for radio broadcasting.
Behringer Xenxy X1204 USB Mixer
thanks
colm
I have exactly the same console, it is a good option.
the main limitation is that it only will have two stereo inputs, the four remaining are mono (for microphone, telephone, etc.)
thanks,
i would be connecting 2 microphones, a cd system and a phone connection.
would it hold up, or do i need more channels
thanks
colm said:
thanks,
thanks
It is ok that mixer for beginning.
colm said:
thanks,
thanks
It has CD/Type IN too (RCA).
hello again,
i have researched this mixer called Behringer X1222 USB Xenyx 16 Channel Mixer.
There is little in price between this and the 12 channel mixer.
I just want to ask you again, would this mixer be good for broadcasting my internet radio station with RadioBoss.
thank you
colm
colm said:
hello again,
thank you
colm
My opinion is that it is a very good mixer.
Decision to take it is all your.
It depends on your needs and preferences. Any mixer will work with RadioBOSS, which means you can choose any mixer you like. USB mixers are recommended because they provide an additional sound device.
