RadioBOSS and Airchecks
Dmitry,
I was talking to a radio presenter at another station and he mentioned that his station does regular Airchecks to help coach and train their presenters to improve their live presentation skills.
An Aircheck is a recording of the show that is started and stopped when the presenter's microphone is activated - so without the whole show being recorded.  The end result is a short recording of the announcements made by the presenter without all the music and adverts - so it's easy to listen to without having to edit and cut up the surveillance recording.
Is it possible for RadioLogger to be adapted to do this ?
Obviously it would be good to have two audio streams being recorded - the whole audio stream - and also the cut down version that records and stores the presenter's audio.
Thanks,  Jamie C.
This feature can be included in RadioBOSS. It already has "Stream Archive" feature (in the Tools menu) and a feature to record MIC only can be added there as well. I've added it to the list. No ETA for now, but it should be implemented this year.
I'd put a +1 on this feature.
Would the stream capture for airchecks be post plug-in processing?
Thanks!
  Dave
The recording will contain the same sound as listeners hear it (including music, any DSPs applied etc). It's just the recording will be synchronized with the MIC button (recording will be performed only when MIC is activated). It's planned for the RadioBOSS 5.2 release - later in September.
