Ramptalk position and size
patrick.de-bruyn
Hello RadioBOSS Team
concerns Ramptalk a question from my FB group
is there a possibility in a later version or update to adjust the size of the Ramptalk display?
maybe in the view/style that you can adjust the size there like with the icons becouse the display of the ramptalk is very thin and small.
and maybe there is a possibility to center it between start and end time of the songs?
Can you please specify what a Ramptalk is? Is it the intro countdown timer?
yes exactly that is what is meant by ramptalk, in and outro
Yes, several users have asked me if the area can be enlarged because it is too small.
Also in my opinion the countdown bar is too small
