elenadudnic83
When the same Track List is used in several playlists does the rotation feature work as a global function - or does the rotation work in an individual manner in each Track List location. Example: We have 12 advert blocks that go to air over a 4 hour period - so 3 blocks per hour. Each advert block is a playlist that holds 2-3-4 adverts. I was planning on putting a station ID in at the end of each advert block. To do this I was planning to use a Track List at the end of each advert block playlist. That playlist used by the "Station ID Track List" would be a common playlist. We would probably set the Track List option to: "Track Selection" = "In order" Is it likely that the "Station ID" track would move to the next track regardless of the advert block that is played ?
