pety Active member Jun 14, 2014 #1 What about read_folder ? What it does ? There is not any description in help. Possible BUG. When I use read_folder in Scheduler it clear entire Main Playlist. Is that it's normal function? Attachments _1_Read_Folder.jpg 39.4 KB · Views: 442
D djsoft Well-known member Staff member Jun 16, 2014 #2 pety said: What about read_folder ? What it does ? There is not any description in help. Possible BUG. When I use read_folder in Scheduler it clear entire Main Playlist. Is that it's normal function? Click to expand... This command should not be used. If you want to load tracks from the folder, just specify its path in the event file name field.
