Hello, the INSVoice feature works perfectly, but it would be great if the expiration date for these voices wasn't limited to that section. I recommend adding tags to identify them within specific songs or artists, and creating a command to enable or disable INSVoice where users could select the tags for voices they don't want to play at certain times during the 24-hour programming. Another suggestion is to be able to select two or three points within a song where the INSVoice should play, similar to the recommended intro (A and B) points. Hopefully, you could also add two or three points in INSVoice to apply to specific artists or songs. It would be fantastic if this could be added in future updates, or at least the tagging feature could be implemented with a command so that users could disable certain artists or songs in INSVoice. I'm not sure if I'm explaining myself clearly, but it would be helpful if the `enablevo` command included the tag name, for example, `enablevo Bee Gees` or `disablevo Bee Gees`. I hope you understand. Thank you.
