Honestly, I am tired of the fact that at certain times I get the same fault, I have used different computers and the failure does not disappear and I do not know what to do to make the program work as it should be, that is, without any failures, will it be possible ? How many more have this problem? in the emission record comes the deficiency of the fault but does not say possible solutions would be good to specify in detail what thing or setting is wrong so that you can correct it easier. after which the program is restarted and that according to the fault it is no longer there, because it does not automatically begin to play the files loaded in the list ?. there is an image in the suficient link with the error "error;" Main device appears to be stalled. Reinitializing "https://photos.app.goo.gl/bof2zjqCCDALYMuHA
