0 = linear interpolation, 1 = 8 point sinc interpolation, 2 = 16 point sinc interpolation, 3 = 32 point sinc interpolation, 4 = 64 point sinc interpolation
When an SSE supporting CPU is present, the default setting is 2, otherwise it is 1.
Hi, I couldn't find any information about Resample Quality in the documentation, too.
My RadioBoss runs on a Windows Server - is the value 1 the correct set for this? Cause with 2 I notice the sound is a little less brilliant, am I right about this?
It affects CPU usage, so if you're not concerned about it, you can set the highest level. Please note that it only has effect when resampling is required, e.g. music track is 44100 Hz and playback device is set to 48000.
