Running on a Server
Gilbert75
I would like to install RadioBoss on a VPS server to run my webradio.
What should I do and what do I need on the server other than Windows ?
It's any sound processing - the integrated Equalizer/Compressor, or any plugins (e.g. VST) that you add.
Yes, RadioBOSS does not require a sound card to operate. You only need to ensure the VPS has enough computing power so it runs smoothly.
Gilbert75
What do you think about this VPS server setup
CPU : Intel® Xeon® E5-2620 Processor
vCPU : 2
RAM : 3 Go + 3 Go
Hard disk space : 100 Go
SSD : Samsung 840 PRO
1Gbits network connection
Unlimited bandwidth
Windows 2008R2 SP1
Gilbert75
Let me know if this VPS configuration is better with Stereo Tool plugin :
CPU : 2x Intel® Xeon® E5‑2620
vCPU : 4
RAM : 6 GB + 6 GB
Hard disk space : 200 GB
Network connection : 1Gbits
Unlimited bandwidth
Windows 2008R2 SP1 or Windows 2012
You have to try it. CPU usage of StereoTool depends on what features you enable there.
