scheduled events and more problem programming
agus7
It is assumed that a license can be used in two computers, one to transmit over the Internet and another to program and other types of things, until now everything is fine, except for one problem: computer 1 to transmit over the Internet; computer 2 to program, etc. If I program the events on computer 2 and copy them into an usb and paste them into computer 1, it does not reproduce the programmed events if a tab is opened where the events would be but the empty tab does not load anything, just pull the tab EMPTY. My question is: because it reproduces the events and playlists on the computer where they were created and not on any computer with radioboss, because the files are anchored to a certain computer instead of being able to use them on any computer with radioboss, since it is assumed that the license is valid for two computers, one to issue and one to program, so it does not help that the license is for two computers, but will you accept events created on another computer? and another thing also the profile configuration (file types, window colors, configurations, etc.) if I copy the profile folder and paste it on the other PC, do they not open because they do not accept the profile of the other computer?
// edited to remove large font size and red color
The scheduled events launch the files on a computer. If you want the same events to work on another computer, you'll need to ensure that it also has the same files located in the same folder.
