Scheduler question
hodgoes2001
Is there a way to turn off the Scheduler actions when the mic is turned on?
As in if i press the mic button in radio boss, the Schedule wont run until i turn the mic off again.
I'm afraid, this is not possible... How do you plan to use such a feature?
Mic and scheduler are unrelated features... What version are you using?
Using the latest stable realease
The idea is so if someone is live on air, the schedule doesn't start and play over the top of them
The idea is good... maybe the scheduler should switch to Manual mode while MIC is on. Probably it will be added in the future versions.
