Search descending order
IgorPobi
Hello !
Why is it (when option Sort Search Result set to on) after starting the program and entering a search, sorting is initially set to descending ?
It should remember the last sorting parameters you have used. Or does it reset to descending all the time?
IgorPobi
Hello !
Yes, the last sorting parameters are set, but after launching the RadioBOSS and searching for the first time, the descending order is initially active ...
