setdtmfsource command issue
mbabb
I have a problem when scheduling the following command in my playlist:
"setdtmfsource http://war.str3am.com:7180/MC01"
When I check Settings | Options | DTMF after running the command, I do see the URL, but the all the characters are lowercase and RB did not keep "MC" capitalized.  It's critical that the MC is capitalized or the stream does not work.  If I manually capitalize the "MC", all is good.
Is this something that is fixable?
thanks,
mike
It could be a bug in the software - we'll see what can be done about it. Thank you for the information.
