Settings -> Style
gg2064
(Settings -> Style) gives the option to change the color for:
Selection color(playlist)
Hot track color (playlist)
Selection color (lists)
Hot track color (lists)
We have used the ability to identify File Types by color in the playlist but the above settings options are only for background color. This causes certain playlist information to be unreadable when selected or hot tracked. Please consider adding the ability to set the foreground (text) color as well as the background color for these options.
File types have their own settings for font and background color, and with custom selection background color, they should still have their file type font color retained.
Hot track and selection settings take precedent over the file type settings in playlists and lists. For example, if the file type is set to black background with white foreground and that item is selected in the playlist where the selection color for the playlist is white then the playlist text is not visible since it is now white on white. Of course, this can be alleviated to some degree with choices of colors but when using many file type color schemes it gets to be cumbersome and limiting. This could be easily solved with the addition of the option to set the foreground color for selection and hot track for playlists and lists.
