Skip voice track if doesn't fit in Intro?
reyfmde
Hi!
Is it possible to just skip the voice track if it doesn't fit in the intro?
At the moment it's just played by it self, no music.
You can specify "Voice track bed" in Settings->Playback->Fading so that voice track will not play in silence. Bed is only applied for the part when there's no underlying music.
I'm not sure how it would be useful, if you add a voice track, you expect it to be played. When it's a long one, voice track bed can be used to avoid it playing in silence.
In my case, i use the voice tracks for jingles that end at the end of the intro.
As they get inserted by the playlist generator, the songs and the voice track jingles are random.
So it is likely gonna happen that the voice track is too long for the songs intro.
And that would lead to weird silence between the songs.
Here are some audio examples that show my problem: https://we.tl/t-rEl8pZQ397
Thank you for the explanation, we'll consider adding this option in one of the future updates.
