N nelson c Well-known member Aug 11, 2012 #1 Hi Dmitry, now buy a professional sound card that supports ASIO. is best to use this driver or should I continue with windows 7?. thanks
D djsoft Well-known member Staff member Aug 11, 2012 #2 nelson c said: Hi Dmitry, now buy a professional sound card that supports ASIO. is best to use this driver or should I continue with windows 7?. thanks Click to expand... Using ASIO will produce less sound latency... If you don't care about latency you can continue using WASAPI.
