There is a small problem in the streaming which is very important to me.
We use studies with FM transmitter site via a streaming online.
In the transmission plant Internet providers have two each assigned to an instance of RadioBOSS, for redundancy.
At the moment a failure occurs in the transmission, for example RB internet provider falls.
Previously, before a court in the transmission when the buffer is emptied immediately he went to the next track. (When he did not specify a time streaming playback)
Now 5.4 this two seconds is silent. (I guess trying to reconnect)
This is very serious for us. At the moment that a cut is detected Playback passed to another instance of RB with another ISP (via the API). As it uses DirectSound and a wide (5 seconds) buffer She spent another instance of the RB, before the court heard.
If you install this version at the transmitter site a 'pothole two seconds "is generated in FM.
Of course we are using the previous version to prevent this from happening. But if this is not corrected we will be forced to stay in an old version (at the transmitter site) to prevent this from happening.
