system requirements for RadioBoss
Hello!
I would like to use my old PC for streaming, and whatever else arises in a webradio ;)
Minimum system requirement of RadioBoss is specified with 800MHz, 512MB Ram,...
My PC is an AMD Athlon 3700+, 1,5GB Ram, nVidia Chipset, GeForce 6200, 2 Terratec Aureon 5.1 PCI,...
Should this be enough?
Also for streaming the next years :) ?
Did you say i should install XP prof. or Windows 7 Home Prof. 64bit?
These two operating systems I had to dispose :)
Thank you :)
If you don't plan using plugins this system will be enough to run RadioBOSS.
I'd advice installing Windows 7 64 bit.
Okay, thank you  ;D
Otherwise thought to Windows XP because it requires less system performance,
But now I will install Windows 7 64bit  :)
