Unexpected closure of RadioBoss
matteolop
after 13 days of perfect functioning.
RadioBOSS rebooted by itself.
here is the error that came out of me.
He does not report any bug reports to me.
Thank you for your future help.
Please click Help->Contact support->Send bug reports, probably it'll help us to see what went wrong there.
Thanks for the answer.
As already said, once again,
It doesn't report any bugs, the number “0” comes out.
(in attachment see the only error that came out)
Please help me in another way.
Can you release a stability update?
Thanks a lot
If you use and VST or DSP plugins, please try turning them off - better turn off support for plugins completely in RadioBOSS.
How often does it happen?
Hello.
what "How often does it happen?" exactly?
I've been using this audio processor for about a year, it's 32Bit (and RB is 32bit too).
but how does a VST or DSP go into trouble if they are important functions for a web radio that actually supports RadioBoss?
how does a function specially supported by Radioboss cause problems?
excuse me.
a thousand thanks
It can if a plugin has a bug, or plugin interface we use has a bug. So if you have it crashing regularly, disabling the plugins is the first thing you should do. There are currently no open bugs regarding VST interface in RadioBOSS, so if disabling a plugin fixes the problem, it's likely there's something wrong with the plugin.
