VST in microphone
Leandrofiorenza
Hi, I have a request, I need to use a VST plugins only on the mic.
I downloaded iZotope nectar and loved it, great, I use my microphone but this is not currently possible.
On the other side when you are adding the categories of music?
Thanks.
Custom effects for mic are planned to be added in RB 4.8.
About categories, what do you expect from it? Please give more information.
I need some way to get better organized my music library
often find the song you want in the library of the PC to the radio I find it very difficult (I have over 25,000 songs)
The idea would be something like the panel "File manager" dela capture software that attachment.
I would also like more commands on the screen, for faster access. my screen is usually many empty lots of space on the playlist. maybe you could divide and put the cart wall.
OK. The search feature will be improved in the future, thanks for pictures, I think it will be like you've posted in "list.png". The "list 2.png" looks overcomplicated to me...
About screen space, one of the next versions will feature "columns" - so you could have 2 playlists displayed at once, or playlist+cart wall and so on.
