radiodungog
After nearly 2 months of perfect on air performance disaster has struck. The sequence of events is as follows:
1. The live show host seems to recall hitting the Scheduler Clear button. Whatever happened the end result was that all 8 schedules went missing.
2. Next the technical support person came in to check things out and decided to get some content playing on the backup PC using a standard playlist. This was done to free up the main PC to do some recovery work.
3. Next the main PC came up with an error message in a small rectangular box and repeated itself over and over across the screen diagonally. We wished we had recorded the error message but we didn't. We rebooted the main PC but RadioBOSS came up with the same error message.
4. We did a re-install of RadioBOSS without uninstalling the old installation but still the error message continued to come up.
5. We uninstalled RadioBOSS and rebooted the PC and did a new RadioBOSS install. This time RadioBOSS was stable but all of our config settings were lost.
6. Previously having not known where all the config settings were stored we had decided to do a series of screenshots of everything we had configured before. We were so glad that we had done this. So we manually reloaded the Settings Preferences, the Schedules and the Playlist Generator configs. I cannot tell you how happy we were to have a printed backup of how those things were configured.
7. We did a few tests to make sure that things were ready to go and swapped over to the main PC again and resumed normal broadcasting.
8. BTW, the main PC and backup PC feed program material out via optical digital audio and we have a $5 optical switch that allows us to switch from one to the other in case of emergency to feed into our studio to transmitter link (STL). This is a very cheap and simple way of switching betweeen main PC and backup PC
9. Total time off air about 5 minutes
10. Total time to recover RadioBOSS and all configurations (except Compressor settings which we did not have a screenshot of) about 3.5 hours
So ... the question is, how could we have done this better ?
Some RadioBOSS config settings are saved to known directories on the HDD whilst others are not.
> Settings > Save Profile as ... saves to a known directory location
> Playlist Generator ... saves to an unknown directory location
> Schedule > Save ... saves to a known directory location
> FX > Additional FX ... saves to an unknown directory location
And there are a few other functions that are adjustable that save to unknown directory locations.
Ideally it would be good to have all of this documented OR saved to a common directory location like /RadioBOSS_Configs
We have broken RadioBOSS before when we were evaluating it. Back then we reinstalled it and lost all of our settings and it was this prior experience that motivated us to create the screenshots. But there has got to be a better way to do this so we don't have to hand enter tick boxes and settings.
Your suggestions for a better recovery method would be most appreciated.
We still love RadioBOSS - it's fantastic
Thanks, Jamie C.
Thanks, Jamie C.
