My CPU is working %60 while Radioboss is working
applejuicetr
Dear Sir/Madam,
My CPU is working %60 while Radioboss is working. CPU fan is working speedly and my notebook is getting hotter.
I uninstalled and setup again but nothing is changed.
I shall be very pleased if you help me to solve my problem?
I am using Vista.3 GB RAM, Intel Core 2 Duo 2.0 CPU
Best Regards,
Serhat Ozdogan
hello, if I may I have a query, you are using an original version?, because the web is circulating a crack of 4.6 RB infected causing cpu intensive.
applejuicetr
If you're using plugins such as VST or Winamp DSP, try turning them off. Normally RadioBOSS consumes about 1-2% CPU.
Try switching to another soud card and/or increase playback buffer size in Settings->Playback->Main soundcard
If software was not downloaded from http://www.djsoft.net, remove it, perform a virus check, and download the latest version here: http://dl.djsoft.net/radioboss_demo.exe
That's true. One guy even wanted to sue us because cracked version didn't work properly :)
Hi,
Thanks for your replies. I am using DFX plugin.
Also i am using External sound card. The program is giving Monitor device error.
Recently it is giving "can not start broadcasting.
are these can be sources of the problem?
Thank you
Serhat
The Monitor device error is not a problem if you don't need to use it.
Try turning off the plugin to see if it makes a difference.
The "cannot start broadcasting" - please let me know what error code is. Anyway, it couldn't cause high CPU load.
Hi,
You are right. I am using cracked version. As you told the problem is this.
I will use trial version.
Thank you so much
Serhat
The crack has a virus... I strongly advice to remove viruses and then install "official" trial version.
