• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: VST's not loading for me?  (Read 16290 times)
« on: April 09, 2014, 07:50:20 AM »
Why are vst not working for me and DSP disable when I use my mic mostly when I stop music, they disable any way to fix this?
  • Administrator
    • http://www.djsoft.net
Re: VST's not loading for me?
« Reply #1 on: April 10, 2014, 04:05:36 AM »
Please give more information on this problem.
« Reply #2 on: April 10, 2014, 05:32:17 AM »
I really can't cause there is no error for me; I just know I add a plugin to the vst folder in Radio Boss vst folder, and nothing loaded and I made my own vst folder as well and had a vst in there and it never loaded at all, so i dont know what vst's are supported to prolly add vst support for stereo tool vst support.
  • Administrator
« Reply #3 on: April 10, 2014, 06:17:31 AM »
RadioBOSS supports all VST plugins except for Shell VST plugins (like Waves). What plugins are you trying to load?
« Reply #4 on: April 10, 2014, 11:40:17 AM »
Here it is I am trying to use this where do i put the dll? http://www.dontcrack.com/freeware/downloads.php/id/4814/software/Stereo-Tool/#
  • Administrator
« Reply #5 on: April 10, 2014, 02:31:20 PM »
VST plugins folder, by default is C:\Program Files (x86)\Steinberg\VstPlugins\
Note that you need 32 bit versions of plugins regardless of Windows version you're using.
« Reply #6 on: April 10, 2014, 04:42:11 PM »
Radio Boss freezes and crashes on me when adding VST's weird?
  • Administrator
« Reply #7 on: April 11, 2014, 02:51:14 AM »
From your previous post, I see that you're downloading StereoTool from some unofficial web site (http://www.dontcrack.com/freeware/downloads.php/id/4814/software/Stereo-Tool/#). StereoTool downloaded from its official web site http://www.stereotool.com/download/ works with no problem here - you should get the "VST plugin version for 32 bit hosts".
« Reply #8 on: April 11, 2014, 04:25:59 AM »
That stereo tool I showed you was a different one a separate plugin.
  • Administrator
« Reply #9 on: April 11, 2014, 04:42:10 AM »
StreroTool, which is downloaded from developer's web site http://www.stereotool.com, works with RadioBOSS.
leslie j keeley
« Reply #10 on: October 12, 2014, 04:25:39 PM »
 ???beta code not going for me
« Reply #11 on: October 12, 2014, 05:11:10 PM »
Not Stereo Tool but Terry West Productions plugins do this crashes radio boss bad?
  • Administrator
« Reply #12 on: October 13, 2014, 02:06:28 AM »
According to our records it was sent to you. Please check your spam folder.
We've not tested those plugins... If they are crashing, it could be for a variety of reasons, a problem in a plugin itself maybe.
« Reply #13 on: October 14, 2014, 02:53:31 AM »
All the plugins I use work fine but with radio boss, they are buggy only with radio boss so that tells me its radio boss not the plugin?
  • Administrator
« Reply #14 on: October 14, 2014, 12:47:08 PM »
It could be that you have lots of plugins, of which one or more are faulty and crash RadioBOSS. Which Terry West plugin does not work?
