RadioBOSS calculates an estimated "Start Time" for each track in the playlist, but this time can be off by several seconds due to features that affect the track's playback time. This also affects the calculation of the total playlist duration.
Features that affect duration/start time:
1. Gap Killer removes silence at the beginning and end of the track. By default, this is evaluated when the track is started. Until then, RadioBOSS doesn't "know" how much silence the track contains, and therefore, the exact track duration is unknown.
2. Trigger Mix At in the Crossfade settings (menu Settings->Crossfades). When the MIX point is automatically detected, RadioBOSS cannot accurately calculate track playback time.
To ensure RadioBOSS calculates the Start Time precisely, either both Trigger Mix At and Gap Killer can be turned off, or tracks must be processed in advance.
In order to process the tracks:
- Open Music Library (menu: Tools > Music Library)
- Add your music to the library
- Select all tracks in the list
- Click Tools > Process Tracks and click the Start button for "Trim silence" and "Mix point".
- Wait until the process finishes and close the Music Library
