Either a X or Tick
mikenico
Sorry for being a Pain in the Butt,could I ask something if poss in later updates, I noticed in the Broadcasting box, if you want to choose what stream to use you click an " tick" and if you wish to enable the broadcast its a
"X"  could we standardise these to be the same  either a an X or a Tick  this does make it easier when training someone as it can get confusing .
Standardising it across the board of Radio Boss  would be  great
Hi Demitry,
As you can see from the attachment that I have ringed in red  there is a Tick and a X can if possible this to be be the same.
This is the way theme engine works - it can't override the system checkboxes in the list (in order to do this we'll have to use low level system hacks, but I don't think it's worth it). That's why a separate checkbox control is drawn according to the style, while checkboxes in the list are drawn according to system.
