• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: New PC recommendation  (Read 1308 times)
DesertIsland
« on: February 20, 2019, 05:58:59 AM »
We are looking to purchase a new PC to run RadioBOSS online only , streaming 24/7 using AAC at around 96/128 kbps.
I see you have a Minimum system recommendation , but what PC specs would you highly recommend in a new system like this.
Is it better to run a single SSD drive or 2 SSD's , one for the o/s and one for the audio files?
Is there any real advantage running RadioBOSS and streaming from the same PC or is it better to use 2 PC's, one for RadioBOSS and one for streaming?
Thanks for any advice.
  • Administrator
    • http://www.djsoft.net
Re: New PC recommendation
« Reply #1 on: February 20, 2019, 07:50:50 AM »
One PC and one SSD disk is enough. For smooth operation, I'd suggest using CPU with at least 4 cores @ 2GHz each.
