Segue Editor of RadioBOSS
Bjorn
Hello, I was wondering If you could add a feature in the segue editor of RadioBOSS that allows you to shorten the track. I?ve attached a photo of what I mean.
The first one is what is happening at the moment and the second one is what I would like. (I photoshopped the second one)
I have also attached how non-destructive trimming looks like in Adobe Audition.
  • 2019-04-05 18-46-27_Trim.mp4
You can set track start and end in the Segue Editor, move the red markers that are in the middle of the waveform - as you did on your screenshots for the first track.
There is a limitation - second track must start after first track. Currently we can't change this, this is planned for one of the next major updates.
It's impossible to tell at this point. We currently work on RadioBOSS 6.0, and as this is a major rewrite in many parts of the software, I can't tell you the exact date when it will be released, and if it will contain feature you ask, I'm sorry.
Bjorn said:
Is this something you are looking at implementing in 6.0?
Currently not, I'm sorry. There are improvements in Segue Editor, the most important is that changes made to the played track are applied right away.
