• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: Command to update computers time  (Read 1484 times)
« on: April 26, 2019, 01:05:25 PM »
I have this solution for German users
Automatic Windows time update by event in the RadioBOSS
Patrick De Bruyn · Thursday, April 25, 2019
First, download the little program down from my Dropbox
https://www.dropbox.com/s/idxnog175p6u2i1/Install2Atomzeit.exe?dl=0
Install it and run it, the first time the update is done, just click YES in both windows.
You only have to do this once.
The program installs itself in 32 bit Windows in
C: \ Program Files \ All time Atomic Time \ Atomic Time.exe
In 64 bit Windows in
C: \ Program Files (x86) \ All time Atomic Time \ Atomic Time.exe
Now open a new event in the RadioBOSS event planner.
At the top left of playlist / title filename or command
insert the following command
For 32bit systheme
run C: \ Program Files \ All time Atomic Time \ Atomic Time.exe / leise
For 64bit systheme
run C: \ Program Files (x86) \ All time Atomic Time \ Atomic Time.exe / leise
(leise is because the two confirmation windows are not displayed)
now you put the hook in time and leave the time unchanged,
select all days of the week, and set repeat to 60 minutes.
Alternatively you can also start the event manually
With this event, your PC clock is updated with the atomic clock in Braunschweig, very convenient for event-scheduled handovers or disconnects
Automatische Windowszeit aktualisierung durch Event im RadioBOSS
Patrick De Bruyn·Donnerstag, 25. April 2019
Als erstes ladet euch das kleine Programmchen runter aus meiner Dropbox
Installiere es und führe es aus, beim ersten mal wird die Aktualisierung gemacht, dabei klicke in den beiden Fenstern auf JA.
Dies muss man nur einmalig machen.
Das Programm installiert sich in 32 bit Windows in
C:\Programme\Allzeit Atomzeit\Atomzeit.exe
C:\Programme (x86)\Allzeit Atomzeit\Atomzeit.exe
Nun öffnet in den RadioBOSS Eventplaner ein neues Event.
Oben an der linke Seite  bei Playlist/Titel-Dateiname oder Befehl
fügt ihr folgenden Befehl ein
Für 32bit Systheme
run C:\Program Files\Allzeit Atomzeit\Atomzeit.exe /leise
Für 64bit Systheme
run C:\Program Files (x86)\Allzeit Atomzeit\Atomzeit.exe /leise
(Das leise ist dafür da das die beiden bestätigungsfenster nicht angezeigt werden)
jetzt setzt ihr den haken in Zeit und lass die zeit unverändert,
wähle alle Wochentage, und setze wiederholen auf 60 minuten.
Alternativ kann man das Event auch Manuell starten
Mit diesem Event wird eure PC uhr mit der Atomuhr in Braunschweig aktualisiert, ganz praktisch bei über Event geplante Übergaben oder Disconnects
vercovn
    • Khóa học tài chính doanh nghiệp
Re: Command to update computers time
« Reply #1 on: October 24, 2019, 10:06:16 PM »
 :-* Thanks so much!
