Add ?ntro column
karahan
?ntro times very important for us. We are talking on intros. so can you add intro column part of search in please?
for ex: This picture
Thank you for the suggestion, but searching by intro is not a typical task, so I'm not sure it we will be adding it. You may consider using an additional playlist tab (or aux player), you can add tracks there and sort them by intro.
I do not agree  your words "searching by intro is not a typical task".
I said intros duration is very important for us. Because we adjust talk for intros duration.
Same time we use radio automation system OPLOG by ?mediatouch Corp. They have.
We don't want to use two programs.
I sent this picture. please check it.
I mean it was never asked before, this is why "not typical". We'll consider adding it in one of the next updates.
