Download and insert track via. API
reyfmde
Hi,
Is it currently possible to download a MP3 file from URL and insert it directly to the playlist via. the API?
You can isue two commands, first download it using ...&cmd=download... (call the download scheduler command via the API: https://manual.djsoft.net/radioboss/en/scheduler_commands.htm
Then after some time (to make sure it's downloaded) insert into the playlist using the inserttrack API: https://manual.djsoft.net/radioboss/en/remote_controlapi.htm
