Using mixer board with RadioBOSS for streaming
Configure RadioBOSS and your mixer board to stream mixer output from RadioBOSS. The general idea is shown on the image:
1. Connect microphones and other audio sources to the mixer. Alternatively, a microphone can be connected to the computer to use with the MIC button in RadioBOSS: https://manual.djsoft.net/radioboss/en/enabling_microphone.htm
2. If your mixer board supports USB, connect it to the computer. The mixer will appear as an audio device in Windows (at least one playback device and one recording device).
2.1. For analog mixers that do not support a USB connection, the mixer out should be connected to the "line input" on the computer, and the "audio out" on the computer connected to one of the inputs on the mixer board, using audio cables.
3. Select mixer as the playback device (Main sound card) in RadioBOSS: https://manual.djsoft.net/radioboss/en/playback.htm
4. Select mixer as the input device (Input 1) in RadioBOSS: https://manual.djsoft.net/radioboss/en/microphone___line-in.htm
5. Configure the mixer board to route the main mix (mixer out) to USB. Typically, there is a button or a slider on the mixer board that does it. This is important, otherwise RadioBOSS playback can be attenuated or absent from the mixer output.
6. Change streaming audio source in RadioBOSS: https://manual.djsoft.net/radioboss/en/broadcast.htm - the Source selector is located at the top right corner, select Input 1 there to make it use Mixer Out for streaming.
Adjustments
Open Control Panel, Sound applet.
1. You will probably need to adjust levels for the audio devices - select the appropriate device and make sure it does not clip or that the sound is too quiet.
2. Sometimes recording devices provided by a USB mixer will use "Mono" output by default. You should change it to stereo:
Getting rid of latency
Use ASIO when selecting the mixer in RadioBOSS (steps 3 and 4), for both playback and input. If a mixer does not support ASIO, you can install ASIO4ALL: http://www.asio4all.org
Hi
Didn't work here at home, going step by step as you describe but it idn't work
The software constantly ignores my analog mixer
Bonne
If you use analog mixer, RadioBOSS will not be able to see it - in this case, it only operates with computer inputs and outputs that are connected to a mixer.
Maybe thats the point
I connect my Line output to the Mixer in an Main input and my playback ouput back to the mixer in stereo channel, the point is that i can't regulate the sound over my mixer, because Radio Boss ignores it, there is permanent sound signal in Radio Boss, it seems that the software didn't work in that way
RadioBOSS outputs playback to the main sound card, as specified in the settings: https://manual.djsoft.net/radioboss/en/playback.htm
This does not involve mixer.
If you want to hear mixed output, then you need to connect your speakers to the mixer.
Done it in that way , step by step as in your description, but Radio Boss ingnores my mixer in constantly
Sorry but it didn't work here at my workstation, search for a user who comes from germany, to talk about in german
What if I dont want to use the built in soundcard (line in Mic in etc)?
Is there a way to set this up with two usb soundcards and an analog mixer?
MIC and Line.In in RadioBOSS are not devices by themselves, you can make those inputs use any sound device, please see the following user manual topics:
https://manual.djsoft.net/radioboss/en/working_with_linear_input.htm
We have connected our broadcasting PC  to USB mixer SOUNDCRAFT Signature10.
My problem: On-air sound does not go to the internet  through the mixer but directly from the Ethernet output of the PC.  The mixer is working only as a monitoring interface of the broadcasted content. I.e. I can prelisten songs in the playback cue and in file directories, I can record announcements into RB with microphone connected to the mixer (VT) and listen back through mixer headphones, but on-air sound is not influenced by the mixer USB  output.
Please find attached setup of my mixer and Playback devices. What is setup wrongly?
Thank you for your kind response.
You need to select the mixer as one of the input devices and then select this input for broadcasting - please see the steps in the first post, especially steps 4, 5, 6.
Buongiorno, sono nuovo della chat, mi scuso se ho inserito la mia domanda in un posto sbagliato.
Io ho una piccola radio web ed ho istallato radioboss, ho collegato al mio pc con windows 10 un mixere esterno beheringer q1202usb, ho collegato l'uscita delle cuffie (PC) con cavo aux 3,5 mm all'ingresso line 11712 del mixer e poi con cavo rca uscita mixer out ingresso microfono del pc.
Ora sembra che tutto funzioni solo quando accendo il microfono la musica non si abbassa e soprattutto il microfono entra con un reverbero che non si capisce nulla. Come posso eliminare questo problema? sbaglio il collegamento?
Grazie
Greetings.
Great discussion. We have experimented with this, with success. It is possible to run the audio from RB through a mixer then back into the computer.
We even made a video. Dmity, with your permission, may I share the link?
https://onlineradiotraining.com/rb33-mixing-live-on-the-internet
I hope this helps.
Kind regards All.
James
Hello everyone, I want to thank James Totton, for his video on how to use an analog mixer to Radio Boss, but my question, can you do something the same but on a USB mixer?
Atte.
Charly
Greetings.
I hope this helps.
Kind regards All.
James
This Video saved me and mine works perfect upto date, unfortunately James I wish you'd make videos about the Remote API.
THANKS AGAIN
good day can some one help me solve this problem a have digidesing mbox 2 and a ddj sz pioneer controller and to live streaming true the mbox 2 but a dry to config it to radioboss but it just playing it true the monitor box and all so radioboss playing true it to
Greetings.
I hope this helps.
Kind regards All.
James
Hello James
Your link here in this forum is no longer working.
I have a German forum and have your Viedeo also embedded there, I hope that's ok for you here the URL:
https://radioboss-forum.de/viewtopic.php?t=4&sid=78b2815f88fb8e968d81c432b65b74b5And here the link to your video
