• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: RadioBOSS Cloud [beta]  (Read 92565 times)
0 Members and 2 Guests are viewing this topic.
  • Administrator
    • http://www.djsoft.net
Re: RadioBOSS Cloud [beta]
« Reply #30 on: October 01, 2018, 07:07:23 AM »
I regularly use the search function. What I would wish, however, that only the searched tracks are listed. Currently all are still displayed but only the searched tracks are marked.
Thank you for your input! We'll rework the search feature soon, and it will show only the found tracks. It will also be possible to search across all folders, not just the selected one.
RBUser2010
« Reply #31 on: October 12, 2018, 10:48:02 AM »
Any new updates for RadioBOSS Cloud for October? I know it was said that by October we will see some new improvements...any idea when these will be live?
  • Administrator
« Reply #32 on: October 14, 2018, 03:16:43 PM »
Yes, there will be two updates with new features in October. Currently they are under development. Some updates require lots of internal changes therefore sometimes the period between updates can be increased.
jordelquino
« Reply #33 on: October 14, 2018, 04:20:07 PM »
Server is down!?  :-\
  • Administrator
« Reply #34 on: October 15, 2018, 03:42:21 AM »
There were problems with "c2.radioboss.fm" server but we resolved them and it should be working fine now.
gaetanlabrecque
« Reply #35 on: October 15, 2018, 05:59:30 PM »
Hello.
I know I already asked about this in the old thread.  But, I would like to use the code you provide in the integration section.  However, only one code is working if I use all of them in the same page.  (I currently have 2 streams with Radioboss cloud.).
In the past you told me to use Frames and that should work.  My problem is I have a wordpress site so it does not support frames.
What can be done so I can have for example the recently played list of two Radioboss Cloud streams on the same page in Wordpress?
Greetings
  • Administrator
« Reply #36 on: October 16, 2018, 02:32:05 AM »
We'll update the widgets to allow using multiple widgets on one page with no conflicts. Please wait when an update with such a feature is released.
Happysound
« Reply #37 on: October 16, 2018, 12:03:59 PM »
Bug?
General crossfade settings
Trigger mix change at level  -12 dB
But after save and then go back in menu I see that the level change to 0.2 dB
  • Administrator
« Reply #38 on: October 17, 2018, 04:17:25 AM »
Bug?
This appears to be the way the controls work, you should use arrows to set the level, in this case it will save properly. We'll find a solution for this in one of the next updates.
David H.
« Reply #39 on: October 17, 2018, 10:03:23 AM »
I saw the radio boss cloud was updated to version 0.4.7.1. Is there a changelog that has been changed or fixed with version 0.4.7.1?
Happysound
« Reply #40 on: October 17, 2018, 01:11:15 PM »
Bug?
I have use the arrows but it don't save this settings.
It only jump back to 0.2 dB if I change to -12.4 but when change to -12 with arrow It stay good.
« Last Edit: October 17, 2018, 01:34:36 PM by Happysound »
  • Administrator
« Reply #41 on: October 17, 2018, 01:39:04 PM »
Thank you for noticing this! There are only internal changes, improving general quality, some performance and other minor issues - pure technical thing, does not really worth a public changelog.
This shouldn't be happening when using arrows. What browser do you use?
Happysound
« Reply #42 on: October 17, 2018, 01:45:34 PM »
I'm using Firefox, but with Chrome same story.
But I find a work around,  -11, -12 , -13 dB no problem.
« Last Edit: October 17, 2018, 01:48:28 PM by Happysound »
  • Administrator
« Reply #43 on: October 17, 2018, 02:32:40 PM »
It doesn't seem to work with non-integer numbers - thank you for letting us know about it!
  • Administrator
« Reply #44 on: October 20, 2018, 01:13:08 PM »
RadioBOSS Cloud 0.4.8 beta
What's new
  • Syntax highlighting in stream page source code editor
  • Ability to change account email in the settings
  • Fixed crossfade settings bug (sometimes settings were not saved correctly)
  • Fixed: it was not possible to save settings in Safari under MacOS
  • Fixed certain stability errors
  • Improved performance
