Ads
jopara
Hello again.
There are some options of the advertising programmer that would be interesting to implement (from my point of view), if they are not already there because I do not know how to do it.
1.- It is possible that when a customer changes the ad, it can be changed directly. Ie right mouse button >> search ad ... (for example)
2.- I have noticed that in the section of alternative tracks of the advertising programmer, the same advertisement is repeated in blocks followed. That is, if the customer has two or more ads, they can be repeated AD1 + AD1 + AD2, for example. Can repeat rules be added to ads?
On the other hand I am not sure how the alternative tracks are programmed in the advertising programmer. Currently I add all the tracks of the same client and after indicating to all their start and end, I only indicate one of them in which time block they go. My question is this: Now a customer indicates that an ad is on air until December 30 and another ad until January 5. If I give each track an end date. Would the announcement on December 30 be removed from the air or would it continue until January 5?
Thank you
If you want to replace an advert, you can replace it in the folder: just replace the old file with a new one.
Currently it selects a random track from all available tracks. We'll consider adding a simple "repeat protection" there, to make it use all tracks before it can select one track the second time.
In this case, you need to add those tracks separately and set their start/end dates separately.
Sometimes this becomes cumbersome, there are commercials that are marked with some title and date and when wanting to replace it goes with another date and title, then you cannot just change the audio and keep the same name. It would be great to be able to enable right click and replace audio, for example.
This is what we want to add in the future versions. There are many improvements for the ads scheduler that we will be adding in the coming updates.
