Bypass DSP for file types
reyfmde
Hi!
Is it possible to bypass DSP and VST processing by file type?
That would be very useful for ad integration.
In our case, because we use heavy sound processing, the beep sound that should trigger the ad server doesn't work all the time.
I've talked about this with the audio marketer (RMS) and they said we should try to bypass processing for the beep sound like you can in mAirList for example.
Currently it's not possible because everything that is playing in the playlist goes through the DSP chain. We'll consider adding such a feature in one of the next updates (e.g. RadioBOSS 6.1).
Hi!
In our case, because we https://showbox.tools/ use heavy sound processing, the beep sound that should trigger the ad server doesn't work all the time.
There's different dev responses too which is interesting. There's a lot with that generic message you quoted, but others saying (paraphrasing) "We are investigating this as this is not our intention, please send us more information to (email)".
Why does it sound like some care and someone else is spamming that generic bs response?
