RadioBOSS Cloud [beta]
RadioBOSS Cloud 0.8.9 beta
Changes
  • Fixed artwork sometimes did not display correctly
  • Fixed various live streaming issues
  • Improved upload music UI
  • Improved Logs
  • Performance improvements
  • Fixed occasional incorrect title when playing network streams
RadioBOSS Cloud patch was released to fix a bug when tracks were cut off in the middle.
When can you share a time table for more feature enhancements please?
Like voice tracking, mix points, and the ability to schedule a week in advance. These are all key things that are required.
I have 9 stations and if they aren't coming soon I'll have to go to a different provider as there has been little progress of late.
We have a general plan on adding new features but userbase grows and we encounter various new problems, bugs, performance issues etc that get the priority so it's impossible to say like "feature X will be added on date Y". In the past months there were ten internal updates, which were not announced, to fix issues and improve service quality. The next feature to be added is track normalization.
This is already possible, the scheduler allows you to select weeks, days of week and dates.
Sorry, you've misunderstood. I mean schedule music a week in advance automatically, currently it picks the tracks as it goes. If you were to have Voice Tracking presenters would need to able to see what tracks are about to play / have played.
You can create playlists with music tracks and schedule them when needed, and this playlist will simply play from top to the bottom and you can see what tracks will be playing next. You're not obliged to use Track List for track selection, manual playhlists are also possible.
Yes I know, but who has the time to create manual playlists! Being able to schedule music from the templates in advance is what we need.
Yes so that you can generate all the hours for a week ahead. That way presenters can voice track their shows in advance and see what is going to play.
I've been begging for this for some time. I've showed the system (which is generally great), but get the "I don't think so" when shown I can't actually schedule tracks (unless I schedule 24 hours manually EVERY day. Ain't happening) and it just 'randomly" picks. Need music scheduler stat.
Any suggestions on how to tighten up playlists? I am looking for something similar to an Hour marker. My hour playlists are close but running over by 3-4 min.
thanks in advance!
I don't think it would be really possible Hour markers are what we plan on adding, however - in one of the future platform updates.
You can use "In order" selection and also turn off "Random" for playlist playback.
I don't think that was the point aaron-anthony was making. We want to schedule the music ahead of time using a scheduller for a week ahead. That way presenters could drop links in. We don't want to have to do this manually as it would be too time consuming
Scheduling a playlist a week or any other time ahead is already possible, I suppose what is needed is automatically creating music playlists like Playlist Generator in the desktop version does? https://manual.djsoft.net/radioboss/en/using_playlist_generator_pro.htm
That would be great, I suggested it at the very beginning of Radioboss Cloud, because the repeat protection doesn't work well when there are two artists on the same song, "feat, ft ..."
OK. This will be available in one of the next updates.
Can you please explain to me how RadioBoss CLoud picks "Filler Songs"?
Lately I have noticed that it keeps choosing the same 2 songs at the top of the hour to fill.
Please help ;)
