Schedual event move to next track if no file found
bassam
Good day,
- using Radio Boss 5.8.5.2, and recently I noticed this problem.
I'm using events to run tracks from folders in specific time, with ("Run scheduled launch without waiting for the current track to finish")
I thought that if the folder is empty, the event will do nothing, but I found that the current track will change to the next one in the playlist without waiting it to finish. I attached a pic of event settings.
Is this a bug or that's how things work ?
if it's a bug did you guys solve it in the recent updates ? (asking to purchase a year update)
thanks
You can download a free trial of a new version to see if it works as you need it to.
I tried version 6.0.5.5, same thing, if the folder is empty Radioboss move to next track in the playlist. Any suggestions to solve this ?! cause not all times I put files in all folders, and I don't want to keep disabling and enabling the events..
Thank you for the details. I have added it to the list of issues to fix, if possible, we'll make it check if the folder is empty and in this case do not do anything.
