Remote connection and disconnection
I have 2 radioboss, one in the studio and the other remote 80 km away, connected by internet through barix.
When the internet is cut the remote can initiate a schedule during the cut.
Can Radioboss detect when the internet returns and connect with the studio team.?
Thanks.
It works well when the audio coming in through the input line (relaystart 1) is cut off. Radioboss starts with the next track in the playlist.
When the audio returns, radioboss does not make the change, it keeps playing the playlist.
How can you resume automatically.
Thanks.
We can't reproduce this issue here using the latest version. It checks the level of the audio in the line input and based on that it decides what to play, input or playlist.
Probaré con otra tarjeta de audio, la que estoy usando es una Presonus Studio24C
Tengo el mismo problema que tu, cuando Radioboss detecta el silencio en la linea cambia a la siguiente canción, pero cuando regresa el audio lo marca como activo pero no entra, se queda con la lista de reproducción.
I have the same problem, Radioboss cuts relay of line input 1 when it detects silence, but when audio comes back it doesn´t connect to line input, it stays with playlist.
