RadioBOSS 6.1 [beta]
Looks like you have the "Stop after this track" option enabled, so it stops after playing the track. In this case, silence detector will not action because it stopped for a legal reason.
This option was not enabled, you can see in the video that the button is NOT in this way
Error messages about server connection does not affect the playback - the disconnect occurs when you have nothing playing, no data is being sent to the server in this case and the server breaks the connection. You can make RadioBOSS send silence when nothing is playing, the option is located in Settings->Playback.
It is very strange but I tried to play the previous video and now the playback starts. (See new video).
But you can see how the encodec stops, even though the option you comment on is enabled
  • NelsonCasey-PC (1 269 288 070)_2021-11-16 08.51.zip
Hello
How can we use the command
"Request message is available with% requestedmsg variable in the notifications" in "Song Request System"
thank you for your reply
Regards
RadioBOSS 6.1.0.1 beta
Changes
  • Mic bed - additional configuration options added
  • Ads Scheduler - ads list now has additional columns
  • Ads Scheduler - added "Priority over the relay"
  • Ads Scheduler other improvements
  • Fixed window painting artefacts when custom styles are used
  • Fixed music library list background color bug
  • Scheduler Events filters state is now saved
  • Fixed "Start next track after mic off" bug
  • Minor UI bugs fixed
x86 https://dl.djsoft.net/beta/radioboss_beta_6.1.0.1.exe
x64 https://dl.djsoft.net/beta/radioboss_beta_6.1.0.1_x64.exe
Plugin
Hello
is it possible to use 64bit VST plugin in the 64bit version of the Radioboss
Many VST plugin is only available as 32bit, will it be possible to use these or must the VST bridge be re-programmed?
What about DSP Plugin can these be used in RB64BIT?
If nothing's playing, the server will usually disconnect the stream, if you have enabled the silence option, please ensure to restart RadioBOSS for this to take effect. Some servers may still disconnect if they detect zero-data.
If it fails to start the event again, please press Ctrl+F4 and make a screenshot of the window, it will show some details to understand what's going on.
You can use the %requestedmsg variable in HTTP requests to send the requested song message to the script. The message variable is filled with data when a requested song is played using the playrequestedsong command.
Yes, the plugin must also be 64-bit if you use 64-bit RadioBOSS. In order to use the 32-bit plugins, you must use 32-bit RadioBOSS.
It would be good if in the Ad Scheduler when you configure the days and times of the batches to go out, it can be selected or activated with a single click. I know that this option is Enable / Disable all, but; one click is faster. It is understood ??
I guess you can use the grid presets to quickly assign blocks, please press the Edit button under the grid to access this.
Bueno la reproducción de video tiene un error al cargar las pistas de video la ventana de video se abre varias veces se cruza luego se normaliza aparece como interferencia luego cuando pones play la imagen de video no sale pero sí el audio
fixed now, thanks, also TTS is working in latest beta
TTS is a mystery, no changes were made before 6.1 release, and also no changes were made in the latest 6.1.0.1 update :)
Please write in English.
Si rien ne joue, le serveur déconnectera généralement le flux, si vous avez activé l’option de silence, assurez-vous de redémarrer RadioBOSS pour que cela prenne effet. Certains serveurs peuvent encore se déconnecter s’ils détectent zéro donnée.
S’il ne parvient pas à recommencer l’événement, appuyez sur Ctrl + F4 et faites une capture d’écran de la fenêtre, il affichera certains détails pour comprendre ce qui se passe.
Vous pouvez utiliser la variable %requestedmsg dans les requêtes HTTP pour envoyer le message de chanson demandé au script. La variable de message est remplie de données lorsqu’une chanson demandée est lue à l’aide de la commande playrequestedsong.
Bonsoir
merci pour votre réponse
La demande devrait être comme ceci « playrequestedsong% requestedmsg » est-ce exact?
Merci et belle fin de soirée
Cordialement
Loic
Good evening
The request should be like this "playrequestedsong% requestedmsg" is that correct?
Thank you and nice end of the evening
Regards
Loic
Changes
i installed the 6.1.0.1 x64, but the about dialog and the program title still shows as 6.1.0.0
Although the name comes out 6.1.0.0, it is actually updated but it appears with the same name, however you can see that if the errors are corrected as described by djsoft
Testing the rendering option, you can see that doing so does not take the custom crossfade with the segue editor, is this an error? looks interesting if it could be applied in rendering.
For some reason the version number was not updated for the executable file. It doesn't affect anything.
Thank you, we'll check if there's a bug.
