Adding File Explorer
patrick.de-bruyn
when adding a file explorer in the additional workspace or on the side of the playlist, only an empty space is created
Do you use default file list, or is it file explorer tree? If you restart RadioBOSS, does it work?
explorer tree and ok it works after restarting Redioboss its al little bug i think
Every time whenn adding a new explorer you have to restart the RadioBOSS to work
It only happens when using tree view
