Radioboss insert time
lughsan
I have the latest trial version installed. How to add time in "ADS Schedule"?
Example:
1 - The Radio tells you the time.
2 - Time.
3 - Advertising 1.
4 - Advertising 2.
In the trial version, I can't find how to add the time in this way.
Awaiting your response.
it is possible to add this function to the program?
how can i request it?
I would like to program a complete schedule from "ADS Schedule"
Example:
09:00
2 - The Radio tells you the time.
3 - Time.
4 - Advertising 1.
5 - Advertising 2.
6 - informative program - presentation.
10:00
1 - informative program - farewell.
3 - Time.
4 - Advertising 1.
5 - Advertising 2.
Easier way would be to have separate events sets - for time announcements, those event(s) you create manually. And create Ads events using the AdsScheduler. Separate them by several seconds, e.g. time announcement runs at XX:00:00, and the advertisement is at XX:00:05.
Thank you very much for the solution.
Anyway, would it be possible to do the modification in RadioBOSS? how much would it cost to do it?
Understood, thank you very much.
another query: what is the latest version of radioboss compatible with windows xp? I tried to install the trial version and it doesn't work.
