Sound Card
Do radioboss come with a sound card and if it do can't i use it instead of my computer sound card
RadioBOSS does not require a sound card to operate, it can work without one - you can stream your audio to the server. It also includes virtual audio cards that you can use to connect RadioBOSS with other software.
Correct, on my server there is no audio. You have to disable the audio device in RB. Audio send then over streaming.
Hi I add tracks to a playlist and I saved the playlist. How do I delete or remove one sound
from the playlist.
Because when I delete that one track it come back in the playlist.
