Feat. in section comment
JeanXeb
Can you tell me if the attribute "Feat." is taken into account in the comment section in TrackTool ?
Cordially
The comment is not processed by the software, it only allows to view or edit it, also search.
Thank you for your reply.
The attribute can however be mentioned in the title section ? and with parentheses ?
Example : For me Formidable (Feat. Pascal Obispo)
You can change the title format for the playlist in Settings->View, and for broadcasting in Settings->Broadcast. Use the %comment variable to include the comment field contents.
Yes thanks !
My question concerns the concept of rules for spacing artists present in featuring.
Can the attribute be mentioned in the "title" section? And with parentheses?
Or should it be put in artist?
Because afterwards otherwise I'm afraid that radioboss thinks it's a different title and plays it twice but by another artist.
How do you recommend doing ? If you can put an example with the "Feat." attribute.
Cordially
Last question I did not find the answer.
How to do when there are several artists featuring.
Example :
Forever Gentlemen Feat. Corneille Feat. Vincent Niclo Feat. Roch Voisine
or
Forever Gentlemen Feat. Corneille; Vincent Niclo; Roch Voisine
Cordially
Forever Gentlemen Feat. Corneille, Vincent Niclo, Roch Voisine
Forever Gentlemen Feat. Corneille, Vincent Niclo, Roch Voisine,
If you use playlist generator it will separate it to different artists. And check the repeats for each of them individually.
