Bug file locked
perezjos
hello ,
I cannot delete a file from the file system as it is blocked by the encoder see picture
I tried to restart the station, then I tried also restarting the computer, and deleted the file from its directory. The file disappeared from the file system but ...when I restarted RadioBoss, the file came back to the directory .(from where ?)
How can I delete that file or unlock the hook on the file please ?
Many thanks
Jose
No, sorry is not recording and is not a new file is the same file and content. I tried to disable the song but the flag does not work, I tried to reduce the start time and end time tags but also it does not work. It is loaded in task for jingles an use overlay to play. It went locked when I stopped it playing from the log window.
thanks
Jose
The "MP3 Endoder" is a process that writes MP3 files, so it looks like you have recording feature enabled, in RadioBOSS or maybe RadioLogger if you use it.
Hi Guys thanks for the comments.
The problem is solved now. I changed the path in the recording window and started another recording and it freed the file.
