URGENT server status
perezjos
Hello
my two servers c13 and c30 are down ! please help !
This server could not prove that it is www.radioboss.fm; its security certificate expired in the last day. This may be caused by a misconfiguration or an attacker intercepting your connection. Your computer's clock is currently set to Wednesday, 7 September 2022. Does that look right? If not, you should correct your system's clock and then refresh this page
thanks
Jose
Hello
thanks
Jose
Same here😔
Guys I was told this was fixed yes I could log back on but it's not fixed just make you aware I have been advised and I quote "The problem will be fixed as soon as possible. We are sorry for the inconvenience! This was after I was told it was fixed. If you want a quick fix internet Radio.com do a free 7 day trail I've moved over to there on an interim basis very easy to switch. Until this is sorted.
It was fixed and it took some time to renew the certificate cache - due to a wrong configuration, the server still uses a wrong (old) certificate for some streaming accounts. I'm sorry this caused the inconvenience.
