Help! RadioBOSS in continuous Crash!
matteolop
Hello, this morning I woke up and found my PC with RadioBOSS Advanced (regularly purchased a month ago) in these conditions ...
I can't understand why ... ??
because?
how come it freezes by itself in this absurd way?
Please Help Me, (we have a WebRadio that needs to be turned on 24/7 and we can't afford these problems.)
he was alone 8 days running RadioBOSS and only this morning he decided to encounter all these errors, not opening anymore.
I had to reboot the machine remotely.
the computer has a Ryzen 5 3400GE processor and 16 Gb of ram with SSD disk with original Windows 10 Pro on it.
I don't think it's a PC problem, or am I wrong ??
can you release a security patch to fix this problem?
If it's a one time thing, it would be nearly impossible to diagnose. Please try clicking Help->Contact support->Send bug reports.
Also try disabling the dark theme and use the regular Windows theme instead, for stability purposes, sometimes non-standard themes lead to errors.
Hi, thanks for the answer.
I'll answer you by point.
As for the bug report, it does not find them, it marks me the same 0 (see attachment).
For the theme, which one do you prefer?
what is the lightest for the precision?
to have a lower consumption on the CPU, I have to leave it on "High" or "Normal" ? (see attached photo)
a thousand thanks
Another thing: installing a second RadioBOSS on the same PC, but on a second disk, does it involve slowdowns or bugs / crashes?
I would like a second instance of RB but no problems.
Thanks so much again :)(y)
Please choose one of the: Light or Flat. Those use standard windows controls and do not involve custom styling - should be more stable.
Additional RadioBOSS installations do not affect stability.
Hi, thanks for the reply.
I have set the default theme.
I hope it won't block any more in the future.
Thank and good day
