Develop a playlist in the studio automatically
JeanXeb
Hi,
I did not find but is it possible to develop a playlist in the studio automatically ?
Cordially
We have detected that if it is deployed by hand before reading the sequences are much more fluid
I have two playlists in the studio that are load. (Screen1)
When the playlist goes to the second the transition is not smooth.
On the other hand, if I manually deploy the playlists before reading, the transitions are fluid. (Right click unfold the playlist)
(Screen2)
Technically, I don't know what's going on in the software, but you listen that the transitions don't have the same fluidity when you deploy it by hand.
I have to specify.
The weather (meteo) file in the screen 2 has a sound bed (screen3)
It's the transitions with sound mats that have the problem
Thank you for the details. I suppose the problem is that the crossfade is not properly calculated when the next track is a "Playlist" because the playlist is not yet processed. We'll fix it in the next update.
Yes that's exactly it!
We also in the same way to detect important silence which are generated during transition if we put information not pass after in file type.
Thank you Dmitry for your listening and helping.
I Have the same problem when a liner is located before a title without intro, RadioBoss can't read the liner, so it generates a micro silence :)
Thank you for the fix ! It will happen in 6.3 version I think ?
