Ability to change size
NestorC
1 - It would be interesting to be able to change the size of these three groups of data, as you can see, the third group, there is a lot of space left over at the bottom
2- It would also be interesting to be able to make a CUE of the third group
This will be improved, thank you for the suggestion.
Can you please provide more information about it?
In this example, if you want to listen to the entire block that will be broadcast at 8:00 you have no chance. It would be interesting to be able to hear it.
By the way, in the second group of data, it would be interesting to have more days, a full month, that could be done by having "tabs" of: week 1, week 2, week 3 and week 4
This is a good idea - prelistening of the whole block will be added in one of the next updates.
By design there's no "beginning" and "end" in the current implementation of the Ads scheduler. So it's impossible to tell what week would be the "first" or "second". If you need different time schedule for different weeks, you can probably use start/end dates, and also add the same Ad to the list multiple times with different dates.
