Request in the multiple action does not have the same reaction
JeanXeb
Hi,
When I make the request in multiple action: (event multiple) (screen1&2)
get file "\\192.168.1.101\nas\MATERIALS\CHRONIQUE\PAD" /newest
The request and not the file is inserted in the studio.
When the studio playing the action the time on it to select the file and load it, it induces a blank on the air.
(Screen3) On the other hand if it is a basic action there he chooses the file and inserts it directly in the studio which is transparent to the reading in the studio.
Cordialy
What RadioBOSS version do you use? Does it show any error messages in the log (bottom left corner)?
RadioBOSS version 6.2.2
No error message in the left pane.
This is odd. If it didn't play, there should be an entry that the folder is empty, inaccessible, or file can't be played. Do you see that it attempts to start the getfile command?
Warning the file is correctly read ...
What I signal is the integration in the studio which is not the same ...
In multiple "event action" it is not the file which is inserted in the studio but the command line.
When the studio arrives on the command line "getfile" and not the file, it takes time to select the file then put it in reading which generates a blank upstream.
But there is no reading problem.
On the other hand the same action in single event does not insert the command line "getfile" but directly the file which is ready to be read in the studio. And therefore no white upstream
Yes, when there's a single command, it's executed right away. If you use multiple actions, and not all of them are commands, then they will be inserted into the playlist and processed later.
Isn't it possible in the studio to find the "getfile" at the time of insertion in the studio? As if inserted as a single action...
